Using a measurement as a parameter
jumpjack_jumpjack
Member Posts: 21 ✭
How can I use absolute Y position of a point as a parameter for my model?
For example, I have a point in (0,100,150): how can I extrude a surface by this "100", so as the extrusion lenght changes upon Y position changing?
I can see the "100" in the measurements panels, but how do I link it to my part?
https://cad.onshape.com/help/Content/measure-ps.htm#Add-variable
Fortunately I found a "measurement to variable" Feature Script.
Can you just make an offset plane from, e.g., the Top plane, and use that as the up-to entity for an extrude?
It's a Foucault siderostat, very difficult to explain in a few words.
