pb with spacemouse pro
olivier_vaujour
Member Posts: 2 ✭
Hello,
I want to migrate from Fusion to Onshape, and I'm checking if it's a good option for me. Unfortunatly my spacemouse pro is not working with it. Right now after reinstalling the driver and re-starting computer only the zoom function is working but no other command. I re-downloaded the latest driver from 3D connexion 10-9-10-b725, but nothing new. I also checked the different options for the spacemouse in the 3dconnexion advance parameters but no configuration is working.
I also checked the Onshape parameters and I didn't found any spacemouse tickbox (as suggested by AI). The spacemouse is working fine with Fusion and Sketchup.
Working under W11 with Edge latest version (Version 145.0.3800.82 (Version officielle) (64 bits). The spacemouse pro is plugged directly on the usb port of the computer (no hub).
I have seen other topics with this issue, but nothing helped me.
Could you help? Thnaks.
As onshape runs in a web browser, and isn't a standard application, it is rather about making your space mouse work with the browser than with onshape. Some browsers appear to require permissions to access devices in the 'network' which obviously includes USB/BT. Does "PB" mean the PB browser? PowerBook? If so: Windows native, or emulated/virtual?
