Getting rid of history in Free Plan?
nyholku
Member Posts: 58 PRO
Hi, I know I can get rid of history (to conserve space) by creating a copy of the work space.
However I'm over 100 MB (in Free Plan) already so I cannot create a copy (to get under the 100 MB limit)! Kind of catch 22 eh?
Why not have a purge history command?
1
However, not having history at all might be something to consider for the free plan users. As a maker, history and branching isn't that important to me, but the 100MB limit is. Collaboration isn't that important either, so what if free plan users didn't have that either? I know these ideas are probably better off in the "Free plan" discussions located elsewhere on this forum, but I'd give up history and collaboration for 1GB of private space over the 100MB we have now.
You might wan't to re-think your suggestion before creating IR for voting
Have the rules changed (again) so that copying no longer gets rid of the history?
Is there some delayed action that shows the document size wrong for some time after copying?
Anyway, I don't insist. Just want to delay that day, when no free space will be left (since hobbyist cannot just buy storage/pay, new account should be created in this case to overcome restriction and preserve old history).
2) Copy workspace and delete original at regular intervals to reduce document size.
3) Download to your harddrive as parasolid or step file when dormant but could be required at a later date for more design work.
4) If you have a private document that will take you over 100MB when you copy the workspace, then make it public before copying, then remake it private once it is copied/resized.
5) Delete all docs private or public that are of no further use as a good housekeeping exercise.
I am having no problem staying within the 100MB free plan limit using the above. If you are having problems then you need to buy a professional use plan as really you must be using Onshape in a commercial venture or be very protective of your own work/intellectual property IMO.
