How can I access a copy of the Multi-Part Hole Document shown in the 9/29 webinar?
edward_petrillo
Member Posts: 79 EDU
I would like to take a detailed look at the air cylinder part studio, but I cannot find a public file for it. Thank you.
Optionscody_armstrong Moderator, Onshape Employees, Developers, csevp Posts: 213@edward_petrillo I can make this Document public. I use model this for demonstration and instruction so its a bit of a mess with random features. I will clean it up and update this post with the link to the public doc.5
Optionscody_armstrong Moderator, Onshape Employees, Developers, csevp Posts: 213@edward_petrillo Here is the link to the doc you requested.
Link5
Below document also made up of Onshape multi-part modelling method. You can refer them for part modelling.
MOTW- VSY PUMP
https://cad.onshape.com/documents/ba533e19081c4c3aaf0745e7/w/908a85957615471ab909945f/e/fe8f9645074e4c7ead193a45
MOTW-VSY MAN PUSHING MECHANISM
https://cad.onshape.com/documents/80a426bfbfb843d498ab4dad/w/ebffb7ab526540ebae82e317/e/3fd25b066f5c476782ad2349
Link
