No preview, no drawing print
thomas_holford
Member Posts: 36 ✭✭
in Drawings
I created an assembly drawing sheet and then used the top left of the screen Chrome "hamburger" menu to access the print menu.
I clicked print, got the Windows print facility screen and a message that said "downloading preview".
After the message went away, there was no preview. Just a blank page. I printed the preview anyway and it printed a blank page.
I disabled uBlock in Chrome and tried to print again, with the same result.
Help.
Help.
Can you take screen-shot and send it to Onshape support team.
I opened the model to the "Assembly 1 Drawing 1" tab.
I clicked on the Chrome "hamburger" icon at the top left of the screen.
The print dialog window opened and displayed the message " creating preview", followed by a blank print document.
The java console displayed the following errors:
"Failed to load resource: the server responded with a status of 401 (Unauthorized)
Failed to load resource: net::ERR_CONNECTION_REFUSED
Does this help anyone figure out why I can't print my On-Shape drawing?
FYI. I don't know if this is significant, but "3dconnexion" is my 3D pointing device.
The other way to print a drawing is to right-mouse-button click on the drawing tab at the bottom of the window, and choose "Export to PDF", then print the PDF file.
Do you mean top right?
@thomas_holford, currently drawings tabs use the Print command in the Onshape "hamburger" menu to create a PDF and automatically open it in a new browser tab.
Users have reported several problems with this process and our plan is to adjust it to match the standard browser print workflow which you seem to be expecting.
