Creating Mate Connector in Assembly
gerald_friedman
OS Professional Posts: 50 PRO
In an assembly when one chooses to create a mate connector one of the options is "between entities".
What does this mean?????
Now I understand.
It might be nice though to be able to select a point between two like features on two parts.
For example, in the image attached, the snap ring grooves at either end of the pin in the image are adjacent to holes in two different parts. The pin is centered between the two parts.
I understand the dilemma.
Just have to offset half the distance from one side.
Thanks,
g
Did you make a support ticket for this, cause I'd love to 1+ it
