How to wake midpoints to use as constraints?
BLJ_ENGINEERINGBLJ_ENGINEERING Member Posts: 13 PRO
Midpoints will not wake unless I choose something new to draw e.g. a new line. I'd like to use constraints directly on midpoints but Onshape tells me; "A constraint must involve something from the sketch".
Did I miss something?
  • derek_wardderek_ward Member Posts: 58 EDU
    @Firesale, you can place points on the midpoints of your rectangle sides, select them and then use a coincident constraint.
  • HakroHakro Member Posts: 57 ✭✭
    I would first create a point at the mid of each of the 2 lines, select the 2 points and then use the coincident constraint.
    Or ...
    Create only 1 point at the mid of one of the 2 lines, select the point and the other line and then use the midpoint contraint.
    Result:
  • BLJ_ENGINEERINGBLJ_ENGINEERING Member Posts: 13 PRO
    @derek_ward and @hakro
    Thanks, that works but I think the "wake midpoint" should be active on constraints also. Oh, and on Dimension also. A huge step-saver!
    Bottom line is; I don't see any good reason for putting it to sleep:)
    I'll "reject" the answers above because it seems that you can not wake the midpoints for this operation. The answers do explain the best alternative though :)
    I am sure there is a more complex reason for them not to wake.
    BTW @hakro ; nice screen caps, do you use Snagit?
    @Firesale: No, I use Jing from TechSmith for screenshots and screenmovies..
