Copy/Paste table in drawing
andy_boyerandy_boyer Member Posts: 4
After creating a table in a drawing I would like to copy that table to another drawing within the same document.  Detailed research and attempted work-arounds have not revealed how to do this.  Is it possible?  Thanks.
    This isn't possible. But would be something that I would also find very useful.
  • robert_morrisrobert_morris OS Professional, Developers Posts: 166 PRO
    It appears to be that you can't copy anything between drawings currently.
    I agree though, it would be really nice to be able to copy text annotations and tables between drawings.
  • andy_boyerandy_boyer Member Posts: 4
    In my research I did note that once you select a table (let's say with the upper left corner dot) so that it turns darker brown, and then hold Ctrl down while selecting again, it creates a copy of the table within that drawing.  Interesting that you can't then take that copy and port it to another drawing in that document.
  • shanshanshanshan Member Posts: 147 ✭✭✭
    andy_boyer, thank you for sharing your research about copying drawing table in a single  sheet to us, I  tried it with your method , it is very useful !
    @andy_boyer That's awesome! Good observation. In my opinion Ctrl+C and Ctrl+V could be better in this case.
  • Narayan_KNarayan_K Member Posts: 379 ✭✭✭
    This works fine for table but not able move leader with note together. if i try the above method to a note with leader then i can copy only leader or only note.but not able to move both.
