Remove border from imported picture
BouwyBouwy Member Posts: 16 ✭✭
edited July 2016 in Drawings
I imported a picture without a border:
Then I add this to my drawing, and a border is added:
Is there a way to add an image without the border?
  • bradley_saulnbradley_sauln Moderator, Onshape Employees, Developers Posts: 373
    The border is there just so you know the boundaries of the image for adjusting the size, position, etc. When you export, say as a pdf, the border should no longer be there.
    Twitter: @bradleysauln
  • BouwyBouwy Member Posts: 16 ✭✭
    @bradley_sauln, the image looks like this in an exported pdf:
  • michael_curry991michael_curry991 Member Posts: 1
    @bradley_sauln and anyone @OnShape who can help.  I have the same problem.  The border is present in the pdf.  The border is only 1 pixel wide so if you view the pdf document at 100% the border may disappear.  Zoom in or print the pdf and the border is there.  Since we add jpg's to assembly drawings this is an issue.
