Export as colored STL
pieter_van_driessche
Member Posts: 3 ✭
Is there a way to export onshape models to a collered STL so it is easy to use as starting point for openFOAM CFD?
Can you do this within onshape or is there an app that can do this?
Thanks in advance
Thanks in advance
https://forum.onshape.com/discussion/4068/stlworkbench-ability-to-import-view-edit-and-save-stl-files-in-onshape#latest
Linked[in]
I will have a look at the STL workbench.
