Mirror part functionality is not enough
konstantin_shiriazdanov
Member Posts: 1,221 ✭✭✭✭✭
I faced the problem that all instruments in part studio that can make a duplicate part actually do create new part, there are no option to make a new instance of the same part. And it would be ok, but in the assembly workflow there are not mirror instrument, and construction geometry instrument. It is a significant limitation compared to SW where one can choose to create a new mirror part or create just a new instance of part in the mirror position if the part has the plane of symmetry.
You can create a new instance of an existing part in a partstudio using the "trasform" function. It has a copy part checkbox so this will create your copy and place it where you want in one operation. You can also derive in as many copies of a part as you wish.
For the assy side of things I might not be understanding your use but it sounds like you could use a layout sketch perhaps? Sketches can be imported inta assemblies and then can be mated to.
I believe a mirror option of a part in the assembly has been requested for a future version.
Not sure if that helps or not.
If the copy checkbox in transform is checked it creates new part which has the same geometry like the refferent part, not the new instance of a part. Using sketches is a tricky way for symmetrical positioning of the same parts. This is sereous lack of basic functionality
Thank you
