Cinematic features, tracked dimentions, Google doc export
adam_mercier
OS Professional Posts: 33 ✭✭
Hello Users and team,
I would like to propose an impovement request for cinematic analysis of assemblies.
We're developping offroad Ebikes. We need to track parameters to tweak the suspension behavior, to do so, we have to measure the relative movement of components on the full travel.
Right now I have to manually record positions over the range of motion each time I want to review a new design, wich is pretty horrible way of working.
What would work for me :
-Record/set control dimentions, same style as part studio level variables, but driven by assemby position.
-Have those variables exported to google sheets and updated as the model updates or with a update command same as BOM
What I would also need :
A way of showing sketches on the assemby level, that would allow virtual pivot point visualisation.
I'm sure those requests would also be interesting to other users!
Can someone from the team mak this post as an improvement request?
Best regards, Adam
Best regards, Adam
3
I would need to have assembly level variables and named/saved dimensions do get some interesting output. Is this planned?
If you select a mate it shows the DOF value which is basically the relative position of two involved mate connector. That is the closest thing we have currently. Will exporting those during animation work for you? When we will have assembly level variable it will probably be tried to existing mate (feature) parameters.
Some partner products may also work for doing advanced motion analysis.
Yes if we could export a mate DOF value based on each step it would already be a big improvement and allow some interesting things.
A dummy mate could work, like for exemple a parallel mate as I tested it here. Ideal would be a completely blank mate with no constraint at all.
I think the core functionality is not too far off, please do it guys!
Adam
