Adding fins to rocket tail...
I'm building the tail section for a model rocket. It's basically a cone (small side down, big side up) with fins attached.
The problem is the fins. I make a sketch and then do a symmetric extrusion.
The edges of the extrusion don't touch the cone.
Is there a way to make that happen?
Can you post the URL of your document here? It'll be easier to help that way.
I modified it slightly as an experiment trying to embed the edge of the fin into the cone.
1. Start a replace face and select the end cap of the face that you want to touch to be the "Face to replace".
2. Select the outer face of the rocket to be the "Surface to replace with". This will try to rip off the face you are replacing and replace it with another one that fits the same surface as the rocket. It will then extend other edges/faces of the part in order to make a valid part. As the face of the rocket is cyclical, there are two potential solutions it could find. If you are finding the fin going all the way through, click "Flip alignment" to get the other solution.
Once the fins are joined to the cone, I want to have a concave fillet to blend the side of the fin into the surface of the cone.
Use Boolean feature to merge fins to the cone then Fillet the resulting edges
It would probably be easier if i'd switched to x-ray view.
Now I know for next time.
