Search Features Feature
This will make Onshape 500% better, especially for new users - have a search box where I can type to search a feature instead of clicking through the menus.
Right now you have to play Finding Nemo if you don't have all the menus memorized.
Microsoft Office and SolidWorks have search functions and it's the best thing since the dishwasher.
    Hello @jimmy_neutron447 !
    Can you raise an improvement request for this from the 'Improvement Request' section of this forum?  Once you do that, others will be able to vote on your idea, and we can correctly prioritize this work.
    @jimmy_neutron447
    Meanwhile, you could keep help site on another window and do a search there?
    Are you aware that you can customize the menus (temporarily remove unused buttons) and also build your own shortcut menu for each context that would popup with key S
    jimmy_neutron447jimmy_neutron447 Member Posts: 3
    Yeah I made my own shortcut menu for adding sketch relations/constraints.
    The search feature is best for things I rarely use, like splitting body, etc. If I don't use them often chances are I don't know where they are.
    I have seen people use the search function in SolidWorks rather than learning the menu and must say I started to do the same for rarely used commands too in my last few years on SW. I'd vote for this if raised as an improvement but plenty other things I'd like to see first.
