Fundamentals 4 - error on Offset value?
bruce_williams
Member, Developers Posts: 842 PRO
www.accuratepattern.com
Step 22 of this exercise asks you to change the dimension on the midplane offset to 35mm, to simulate design changes, and their effect on the geometry. Step 21 asks you to make changes to the master sketch as well. These steps must be followed to get the correct answer. Thanks!
Is this the best place to post these kinds of questions/issues?
*And by read I mean skim through.
Owen S
You can use the "ask a question" option in the Learning Center for these kinds of questions/issues.
Thanks!
