How can I create a rip joint on a face?
jeff_davis
Member Posts: 7 PRO
First, thank you for the awesome sheet metal functionality!! I am working on a semi complex part. Sheet metal got it almost there with very little effort. The only issue is that I need to create a rip joint on the highlighted line to allow the part to unfold. What is the best way to do this? I tried extruding the solid before converting to sheet metal, but that seemed to cause even more issues.
Optionslana Onshape Employees Posts: 696@jeff_davis
Please see how I've used your sketch to split the face of the input body
https://cad.onshape.com/documents/8c34cf827eec23a32eeb8b63/w/48f718b6075b44bb8c793348/e/cac65e1d0593c4a0847acc00
5
We don't currently have the capability to add arbitrary rips; it would be great if you could add an improvement request for this on the the 'improvement request' section of this forum.
For now, there may be a few different ways to get the geometry you want (we'd have to see the part you're converting though), could you either post a link to your document (if you don't mind it being public), or use the ? menu > 'Feedback' button from inside your document to report the issue you're having.
FYI @lana
- I also included a very similar part that was created in solidworks with the geometry I am after.
Please have a look https://cad.onshape.com/documents/ee29a79c8487beed4477908a/w/33e47c072d54704a3c2896d9/e/a19dea01a51705d73dce09a2
This should be something similar to what you're after.
I did put in a feature request, but this seems like it does what is needed in most all cases. I'll see if I can put a link to this post in the feature request.
Glad it worked. The fact that split before convert gets you the same geometry allowed us to de-prioritize Split feature for sheet metal. We'll get to that IR at some point.
