Flat patterns and drawings
Research_01
OS Professional, Mentor, Developers Posts: 301 PRO
Two questions and I may be just oblivious to the answers:
1. How can one when in a drawing insert a flat pattern? It is not in the insert view menu and I would hate to have to make a new drawing every time I need to add a flat pattern view. I want them all in the same drawing tab
2. How do I get rid of the bend text? I cannot hit delete, ctrl x or command x is not working and right clicking does not give me a dialog to remove the text. See the pic below for the text I want to remove.
LearnOnshape facebook group
Great questions.
We should have the "Hide bend notes" command on the bend note text. I'll write a bug to fix that.
To insert a flat pattern into an existing drawing:
- In the drawing toolbar, click on the Insert view toolbar button
- In the dialog that appears, click on the little button on the left side to open a second dialog
- In the second dialog, make sure you have chosen Part Studios
- Then right below the search text box, there are 3 icons. Click the far right one - with the tooltip "Flat patterns".
- Then below the 3 icons in the dialog, click on the part studio and then on the Flat pattern of xxx choice.
That should result in you inserting a flat pattern into your drawing.Thanks -Bob
