(solved)rotate one part studio in assembly
macdony_denis
Member Posts: 24 ✭
Hello,
I would like to turn a part (part1 (5)) of 30 ° in assembly.
When I select (part1 (5)) all the parts turn?
the link :
Https://cad.onshape.com/documents/5906de549c5a8610db944cc4/w/f17492959030ec1ca681df96/e/654369690454d9a239a764bd
thank you,
Denis.
Bonjour, je voudrais tourner une pièce (part1(5)) de 30° dans assembly.
Quand je sélectionne (part1(5)) toutes les pièces tournent ?
le lien :
https://cad.onshape.com/documents/5906de549c5a8610db944cc4/w/f17492959030ec1ca681df96/e/654369690454d9a239a764bd
Merci,
Denis.
the link :
thank you,
Denis.
le lien :
Merci,
Denis.
Are you having a similar issue? This is back from about a year ago, so its unlikely Denis will see it unless you tag him like this: @macdony_denis
