EN standard materials database
all european users need EN/DIN materials
    MBartlett21MBartlett21 Member, OS Professional, Developers Posts: 2,034 EDU
    edited April 2018
    You can create your own materials database
    claus_jeppesen817claus_jeppesen817 Member Posts: 39 PRO
    Yes I know
    It seem not futile that thousands of individuals should create the same  database consisting of all metals
    I was searching for "Aluminium" the other day. It is spelt "Aluminum" in their materials.
    I have created my own and changed their spellings to Australian.
    Also:
    Is there any way to get a csv of materials from Solidworks?
    miczechmiczech Member Posts: 8 PRO
    +1 please create such a library
    Also:
    In SW you can open it material library as xml and parse it. I used wolfram mathematica for example.
