Edge to edge centre line & centre mark.
brian_pinder662brian_pinder662 Member Posts: 119 ✭✭
When trying to use these two features in drawing, I find they will not work in projected views. This is a topic I have posted previously but thought I had solved. However not so, Can anyone say if this normal or is there a problem that anyone can help with. I have a spiral stair landing with handrail  that I am trying to dimension to the centre line, also holes in which I would like to place a centre point.
Thank you   Brian.
    NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,395
    Sounds like your edges might be made of splines - a centerline can only be created on arcs and lines - can you post a link?
    Brian - as always, to get the best answer, please post a link to the document or a screenshot highlighting the problem you are experiencing.
    We look forward to helping you.
    Philip Thomas - Onshape
    A little embarrassing but never posted link before , could you please explain how to do this or screen shot.
    thanks for your replies. Brian.
    Hi.
    Happy coincidence, just happened to post this recently:-
    https://forum.onshape.com/discussion/comment/39686#Comment_39686
    Cheers,
    Thank you Owen, will do this. Maybe someone will be  able to show where the problem is.
    Enjoy rest of your day. Brian. (From a very wet Sheffield at the moment)
    https://cad.onshape.com/documents/cb47a08bebe5fcac79fc7aed/w/6a5b5ceb93a25da19985dbcc/e/7d8c252606c2e47cdfdf0b58
    This is the link to the problem Drawing, It is the section and the projected views where I find the problem.
    It's because it is a section view (though why that should matter I don't know - please report as a bug). Create an auxiliary view instead - that works.
    Thanks Neil, Will do.
    Brian
    PeteYodisPeteYodis Moderator, Onshape Employees Posts: 519
    edited April 2018
    @brian_pinder662 @NeilCooke We have a bug currently on centerlines and centermark creation on angled section views.  A fix is coming.  I suspect that is the issue you were hitting here.  If it was not, I would encourage you to submit a bug report using the tool in the help menu.
    Thank you PeteYodis, Yes this is the issue ,
     Regards Brian (Have a good day)
