How to rotate the text of a dimension in a drawing ?
micdominmicdomin Member Posts: 16 PRO
The text appears automatically parallel to dimension but cannot be rotated afterwards
    edited May 2018
    Sorry I didn't read the question properly, I thought we were talking text in sketch entities.
    Delete the horizontal and vertical constraints on the outline rectangle, then apply a fix constraint to one corner, then drag any of the other corners to rotate.
    Cheers,
    Thank you Neil but I see that it works also with ISO, I just missed the option in the "properties" options panel
