Slow and Inconsistent Speeds
I'm finding Onshape getting slower and taking MUCH longer to load now. Speed tests and system checks are fine, no issues.
One support ticket said I had many tabs in my project that take up a lot of resources so they increased the resources for the one document I'm working on.
It improved on and off for two days. I'm back to the same issue now and its so very frustrating when all your work in online and you can't access it.
It has become a habit now to export everything so I can access it when needed because of the uncertainty. Should not be this way.
Anyone else having these issue?
Yes I've tried different locations, computers and browsers.
Here is an example.
I have received good help from support when I have run into problems and I know the team are working hard to improve speed and solve these problems. All I can say is keep reaching via the email with your support ticket.
On the number of tabs, I've never been told that I have to many tabs in a doc but have been told to limit the number of tabs I open the browser.
