two materials
alan_brunsman706
Member Posts: 7 EDU
I want to change materials in the part. Can I make a part from two materials? Or does it require two parts in an assemble? I have a printer that will print from two filaments. I do not know how to draw the part so that the printer will accept the two materials. The printer has a sample program that switches materials with different colors but I can not see the code.The printer is a XYZ 2.
That printer requires 2 stl files - one for each material.
So now we know we need 2 stl files - one from each of two parts.
You have several options.
When exporting as stl from a single part studio: either export them individually, OR, export the entire part studio and select the option to 'save in separate files'
That should get you going
@philip_thomas speaks the truth. (T-shirt forthcoming, it's generally worth listening to what he says... )
Just because it's two files doesn't mean they don't touch each other. If they touch and they're made from melted plastic they fuse into one solid seamless part. This is indeed how multi-material print slicers tend to work
Happy printing.
O.S.
