Export to Step
Harish.Telanakula@Honeywell.com
Member Posts: 3 ✭
Hello Team,
I need to export the part studio into STEP format using API keys but I am unable to do that .
I am facing the below error .
{"message":"Unauthenticated API request", "status":401}
You will need to share the document with the application.
To share a document with your application, click on share, then choose "application", then, in the drop-down list, select the name of your application. All you should have to do then is hit Share.
If you are using API keys, rather than oAuth, it should already work
Maybe @billy2 could help
