Introducing Link tab
lougallo
Member, Moderator, Onshape Employees, Developers Posts: 2,001
Have you ever wanted to simply add a tab to Onshape and have it show your Google doc or any other sites you use often? This was something I have wanted to do for quite some time and finally we can do it now.
Link Tab is an integrated cloud app that allows you to create tabs in your Onshape documents that contain hyperlinks. This is a great way to use your Onshape document as a gateway to related data and services. For some services, like Google apps and YouTube, will automatically embedded and usable directly within the Onshape Tab. For others, the Onshape Tab provides a convenient way to launch the hyperlink in a separate browser tab.
Check out Link tab in the Onshape Appstore! Hope this helps a few of you out! ~Lou
17
If you are looking at doing future updates, then the option to create a new Google Docs or Sheets document from the Tab would be amazing. This would then tick off my need for some sort of notebook to write project specifications etc alongside the designs
i can't achive the result on your screenshot, in some moment even the notebook content appears but in the end - "The following link was prevented from being displayed in this tab".
CAD Engineering Manager
I want to throw my support behind this effort...as a G Suite company, this would be really, really helpful. Thanks for sticking with it!
How would I do this without a google account?
We can't access them at school
Thanks Lou
It show this.
I'm having a problem with Link Tab, and after reading through this thread I can understand what's going on, but wanted to let you know.
I have a document with Link Tab added, and a Google Sheets BOM in the tab. I share the document with View access to collaborators. They can't see the Link Tab content (but also can't add the Link Tab app because they only have View access!).
I'd like my instance of Link Tab (with my "anyone with the link" google doc embedded in it) to work for other View only viewers of my Onshape document.
I think the issues you describe above with Google accounts and authentication issues are part of this.
Thanks for working on this; it's going to be amazing.
Will try and give one of the viewers Edit access so they can add Link Tab, and see if that helps.
Thanks
romeo
This is such a great app. I'm now able to view and edit key spec info, change logs, etc that I store in Google docs as well as linking to external specs such as my chosen 3D printers design guidelines, etc.
Very many thanks for making this available.
I had this issue in chrome - was able to sign in using Firefox. Thanks for the cool app!
Thanks Lou
Next step:
Link sketch dimensions (or other variables) directly to spread sheet?
One plus on the feature request though:
Being able to pull variables from a linked spreadsheet would be super awesome and increase the usefulness of this app significantly.
