Automatically set drawing configurations to current part configuration
I think it would be helpful to be able to set a drawing to whatever is the currently selected configuration in the reference part. I'm creating a configuration for bicycles and each tube is it's own configured item so it would be helpful to know that a drawing matches whatever part configuration I'm currently looking at. Otherwise every time a drawing is referenced I need to double check the configuration settings to make sure they match for each tube and it's likely something will be missed when I move to fabrication.
A workaround you could use for now is to create a Part Studio with one "Derived" feature which derives your configured part into that studio. Then, update the configuration in the derived studio and the drawing will also tell you that it needs an update.
Thanks Jake, although this could be useful in certain situations and maybe I'll be able to utilize this for some other drawings. In this case I will still need to make some adjustments in the main part, and so it becomes a matter of updating configuration settings to match in the drawing vs. the derived part.
