What do _you_ use driven dimensions for?
michael_mcdonald047
Member Posts: 23 ✭✭
Are driven dimensions just for saving the trouble of consulting a calculator or is there more to them. Referring here to driven dimensions within sketches, not drawings. The value of adding reference dimensions onto a shop drawing is clear, but why within sketches?
Michael
I will add several reference dims, right click them and set them to driving. This will over define the sketch but hold things in place as I set existing dimensions to driven. Essentially I'm swapping which dims or constraints drive the sketch.
I find that purposely over defining the sketch can be a great way to trouble shoot with more predictable behavior.
