blind hole at angle
stuart_hatherwaystuart_hatherway Member Posts: 8
Hi
I'm trying to insert a blind hole at an angle. I read up and it was suggested drawing a 3D spline along the path the hole will follow and then setting a point normal plane off of the vertex to work from .
I have done this but cant seem to locate the hole at  the end of the spline and face of the plane.
Any ideas would be appreciated or is there an easier way to do this. Thanks
regards Stuart
