blind hole at angle
stuart_hatherway
Member Posts: 8 ✭
in Drawings
Hi
I'm trying to insert a blind hole at an angle. I read up and it was suggested drawing a 3D spline along the path the hole will follow and then setting a point normal plane off of the vertex to work from .
I have done this but cant seem to locate the hole at the end of the spline and face of the plane.
Any ideas would be appreciated or is there an easier way to do this. Thanks
regards Stuart
https://cad.onshape.com/documents/5d3462b436a8cf4265e728a6/w/fcd6c0280c91a52556d70e4a/e/d2b097057ddd9462df292013
https://cad.onshape.com/documents/a3e1c5175b3501dc1d54221b/w/d638e5ad4b47b3b9629ab0e3/e/accaffa1550d2d9e7ce4bfe0
Onshape, Inc.
Looks like you're almost there! Only sketch points can be used to make holes, so in sketch 6 you'll have to "use" the endpoint of the 3d spline:
https://cad.onshape.com/help/Content/sketch-tools-use.htm
Then once you have the point in the sketch, you can use it as a selection for your hole.
Once I did this, I was able to make the hole, but the geometry was weird because the starting plane of the hole cut through the model:
My solution for this was to make the plane exist entirely outside the model by using a line-angle plane off of the top edge of the part (using the 3d fit spline as a reference for the 'angle' parameter):
And then when the hole is built, it looks correct!
https://cad.onshape.com/documents/2620010a4da4c8f7a133c0b1/w/9e7cee4aaffe4168a077601a/e/ce0e0b56800127f2659b165c
