I have to agree about Solid Edge ST. 'Synchronous' does look impressive in the product videos and demos, but falls flat on its face when dealing with any moderately challenging geometry.
Synchronous and surfacing? Not happening.
Synchronous and anything beyond prismatic objects? Not happening either.
Onshape's direct edit tools also work best on prismatic parts, but at least their importance is somewhat understated (as I think is most appropriate). Solid Edge pretends ST is the solution to all design problems, while it is only a hammer to a very specific nail...
Dries
While I love SE's direct modeling environment, Parametric is nice when you already know what your design is going to be. DM is way better if you're not quite sure.
This is defenitly what I was talking about! Thanks @Jon Banquer I will survey their developpement.
DriesVervoort_Caradon: SolidEdge was one of the first CAD software to propose both solutions with the same license. Of course they want to promote it as much as possible
Also maybe I guess we must try to change our working uses to adapt ourself to the direct modeling technology. But so far I agree with you, we can't do everything...
Onshaper: I also agree with you, if you are not sure of your expected result, direct modeling is a great tool. Probably the best if you only have a single piece to draw.
If you have many hours on SEST, I could forward you a simple family model and let you try to model it with SEST? It might be an interesting test. Of course it is possible that I missed something as I usually use parametric mode.
What do you think ? ^^
What are you talking about?
(This example is not from Synchronous, Synch is still a baby).
Or do you mean that first to make nice looking model and then scale for intended size? This kind of thinking might serve furniture design as well.. hmm
What about standard parts? How do you use M8x30 bolt to connect things if you don't dimension hole&thread for it?
You can delete dimensions from parametric model, then it's just not that parametric anymore.. I'm not slave of dimension, I would say dimensions are my slave and I'm the master who makes them dance
Please do remember, I'm not trying to prove you wrong here - I just wan't to understand how to design without dimension; your religion. I'm almost self learned to cad world (1 course 15 years ago), so I haven't read from the big book year after year that I should use dimensions; I have just found it useful way to make things in right size.
I tried recently software called solid face, at first it felt pretty good. But after sketching everything in place and wanted to set the holes suitable for 8mm dowel, I didn't find dimension tool - exit sketch --> un-install + registry clean.
So... What are you doing here?
Usually most of us reserve "furniture" for chairs, sofas, couches, and other not always upholstered but virtually always movable items, including free-standing chests of drawers, but not (except in more technical contexts) items which are built-in. So it brings to our mind things which are not generally orthogonal or primitive in form.
Your English is so excellent that many here will be surprised at my suggesting you are not a native speaker, BTW, so I hope I have that right (and some may disagree with my guide to usage, which should carry a disclaimer, like all such guides: English usage is notoriously variable)
@Andrew_Troup You might be right, in Finnish word furniture means the same as in English (by dictionary) - but what you actually think when using the word might be very different. We divide basically in two categories soft and hard - and I'm in the hard side. The easiest global term would probably be 'Ikea type flat-pack furniture'.
And as the clever ones already picked up between the lines, I'm not even close to native English speaker. Thanks for the complements though.
Jon you have got my vote. Do you have any idea at what point of gestation CADstack is at?
In the meanwhile I'll keep on using SpaceClaim.
As for Onshape's tools; it's JUST enough so you can make basic changes to imported geometry.
And that's the thing about DM. I can import geometry from any program into SE:Synch and edit it because no history tree is required.
And as for parasolid being parametric... not quite. SE:Synch is Parasolid kernal.
If Onshape can build direct modeling into the package successfully, great. I'd look forward to getting my feet wet in that area.
- Can you do pattern/mirror and come back to edit in same dialog?
- Can you set relations to dimensions ie. D3 = D1+D2?
- Can you have global parameters or spreadsheet driven designs?
- Can you have configurations (where difference typically would be different parameters and having some features suppressed)?
- Can you have named dimensions and show them in BOM?
