feature folder
ofer_katsirofer_katsir Member Posts: 2 EDU
when creating a single part studio with multiple objects it is very common to have many features.
if i could select multiple features that create on of the parts in the part studio and collapse them into a folder (wich will show in the feature list) it would make the part studio look much more readable.
see attached photo i created as an example.
the folders will not be automatic but the user will select wich features to mask into the feature folder.
  • owen_sparksowen_sparks Member, Developers Posts: 2,095 PRO
    edited October 2018
    Hi @ofer_katsir and welcome to the forums :+1:
    This is currently the most voted upon open feature request.
    Please add your vote here:-
    Cheers,
    Production Engineer
  • 3dcad3dcad Member, OS Professional, Mentor Posts: 2,371 PRO
    And something to think about - what if same features are partly used for motor and handle. They could originally come out from same sketch or have shared holes / fillets .. etc .. you get the point  ;)
  • bradley_saulnbradley_sauln Moderator, Onshape Employees, Developers Posts: 249
    Also, if you click on a part/face it will highlight and scroll to the feature that was used to create it.
    Twitter: @bradleysauln
