BEST APPROACH AT GENERATING MULTIPLE DESIGN VARIATIONS BASED ON A VARIABLE-CONSTRAINED PART STUDIO
fluvio_lobo_fenoglietto
Member Posts: 36 PRO
Hello,
I need some advice on how to approach the following idea.
Given a Part Studio and a single solid defined by a number of variables, I want to automatically generate variations of said solid and export them all as .STLs or .STEPs
In more detail...
My current logic follows (high level):
My best guess to do this;
I look forward anyone's time, help and feedback!
Again, I am just looking for guidance on feasibility before getting my hands dirty.
Thank you,
Figure --------------------- ;
In more detail...
- Imagine a hollow cylinder defined by 3 variables (inner radius, outer radius, and depth) [Figure]
- I need an app or FatureScript that generates variants of set cylinder by changing the values of the 3 variables
- Create a variable-constrained solid in a Part Studio
- Create a FeatureScript that reads the variables of the part studio, creates a new solid with a variation of said variables
- Create an external app that: (1) duplicates the original Part Studio, (2) executes a FeatureScript that alters the variables of the solid within the Part Studio, and (3) Exports all of the Part Studios
Thank you,
That said, does this really need to be automated? How many permutations are you trying to export? If it's a manageable number, I would just use configurations and export manually. Alternatively, if you don't need individual files, you can insert multiple configurations of the same part into an assembly and export the assembly.
As for configuring variables, if the variables can only have certain values, those values can be configured as a dropdown list. If the variables can be any value, then use a configured variable. Below is an part studio with examples of several types of configuration inputs.
https://cad.onshape.com/documents/57acdfaae4b005c413ed9b6f/w/3fd585a46d3af1b3ba413c53/e/b02ec721136c6121c1a02cc1
https://cad.onshape.com/documents/7cdcfcfdefc81485592c83b1
You can then export as individual parts
A manual version of this can be found here:
https://helioztechnologies.com/onshape
This example shows how the API can drive Onshape configurations.
