Rubiks Cube mate / animation
2»
    That's crazy but very cool
    edited December 2018
    If you designed only those trajectories themselves it would already deserved admiration  :)
    Those are some funky looking Christmas decorations there.
    :star::star: :star: :star: :star:
    Wow, it actually runs great!
    And I'm glad you got this out of your system, I'm sure you will be better father, husband and citizen now =)
    Definitely a model of the month (or even model of the year). Onshape should make a blog post of this, I've already had fantasies how to implement 'your technology' to animate furniture assemblies in Onshape.
    MBartlett21MBartlett21 Member, OS Professional, Developers Posts: 2,034 EDU
    Maybe ask @NeilCooke
    Great work John. Glad you finished this.  You are now probably also the biggest comput power user on the Onshape server.
    john_mcclaryjohn_mcclary Member, Developers Posts: 3,897 PRO
    I think that still goes to that single part studio conveyor showcased in philip's performance video XD
    Ok, I haven't seen that one, I'll have to take a look. Does it show examples of workflows to speed models up?
    Yea, some pretty good ones, a few of which I used in this document. Worth a look.
    edited February 2020
    It's 3am... I can't sleep...
    So, Let's try and make animations in Onshape even simpler... Remember how I had the sketch grid, and a crap load of sketches for each path.
    Let's try it in a spreadsheet this time.
    And how about some easing curves to smooth out the animation steps as well  <3o:)
    While we're at it, lets get rid of all that duplication of effort and minimize tabs and sketches and make it re-usable:
    Sneak Peek:
    https://www.youtube.com/watch?v=vqgWhkS6OPA
    steve_maiettasteve_maietta Member Posts: 54 PRO
    @john_mcclary
      Very inspiring.  I'm working with students this month dealing with all sorts of mechanisms and animations.  (Hence all these posts as of late).
    In the rubix cube project, a few questions if you don't mind.
    0- How do you get the "pusher" (pointing towards the end of the track). to move the pointer (pointing down towards track)
     1- How do you get the pointers to stay vertical (pointing down at the track) as they slide along (tangent) the track?
    2- How do you translate their vertical motion to a rack and pinion mate?  If I put a slider mate on the pointer it can go up and down, but then gets locked into place on the track. No slider mate, then I cant use the R&P relation..
    The pointer I noticed has two mate connectors at one of its corners,,,  I assuming these help in the above situations?
    thanks for clarifying this a bit!!!
    ~Steve
    Document I'm using to try this out
    https://cad.onshape.com/documents/bec83899b97e0f93439c33bf/w/855b74a0d979f601d5d530f6/e/3d9c45deef0239701c47e85e
    I have a vertical slider attachedtto a fixed part or each axis of each part. That same part also has a Tangent that touches the guide track.
    One of the videos above explains the entire process, it's a long videe, but i walk through adding one of the animation steps
    brayden_mcdonaldbrayden_mcdonald Member Posts: 4 EDU
    For me the animation doesn't work :/ why is that maybe?
    It takes a minute or so to start moving
