Need some advice on FILL component
franz_balleis127
Member Posts: 22 ✭✭
in Drawings
I have the problem that I can not connect the two surfaces with par1 by the FILL option
It seems, I have a problem to define the GUIDE route
I'm not shure, maybe the point (3) is the problem. It seems that there are not the same values for the both circles. But all ist controlled by parameters so both should be the same.
(1) radius = #Grundhoehe / 2
(4) point 4 = #Ansaugdurchmesser / 2 downwards from point (3) of circle (1)
(2) radius = #Ansaugdurchmesser / 2 centerd by pouit (4)
(3) Point 3 should be the result. But it seems that this is not the same radius ????????
Maybe this is the reason for the problem to combine.
regards Franz
regards Franz
