I would like to be able to add note attached to a sketch dimension in part studio
Kevin_Quan
Member Posts: 2 PRO
When adding a dimension sometimes it is nice to have a note attached to it. For example, when a dimension is based on an ISO specification or some standard it is good to see the standard as a static reference especially if the dimension is deviating from the the standard. In solidworks I was able to do this in dimension text in the dimension property manager.
2
I found a similar one here.
https://forum.onshape.com/discussion/8526/add-notes-alongside-dimensions
