Importing parts into Part Studio
mark_proulx
Member Posts: 48 ✭✭
It does not appear to be possible to import parts, e.g., .stp files into a desired Part Studio. Instead, it appears that one must create an assembly to permit their integration. Is this true? If so, what is the rationale behind this architecture? I find it profoundly frustrating.
My biggest problem is that I'm an intermittent user. I jump in, do a project, then don't return for an extended period. As a result, I spend most of my time at the steep initial stage of the learning curve. It was the same way when I was working (I'm retired now), where we used specialized structural dynamics software that was pretty cryptic. If you didn't have your nose stuck in it all the time, you were destined to struggle. By comparison, my problems here are not nearly as daunting.
It is my mission to get increasingly comfy with mate connectors. Thus far, I've found them to be an annoyance, but willingly concede this to my inexperience.
I never pose a question to the forum without trying to work it out via the online help!
Thanks again!
Mark
