Double click to edit sketch and feature dimensions in 3D area/view
eirik_r_guttulsrud
Member Posts: 23 PRO
in General
Hi all!
I want it to be easier to edit my existing sketches and features, like the depth of an extrude and sketch dimensions, in the 3D view/area.
Double clicking on a sketch entity, in the 3D view, should bring me right into edit sketch mode, so I can edit dimensions, like when double clicking the sketch in the tree. Now you have to double click entity and then double click a dimension to get into edit sketch mode. Not a big deal but it is an extra double-click
Depth etc. of features should also be editable by double-clicking the geometry in the 3D area. Sketch dimensions appear, but not the extrude depth, in the case of an extrude.
You're nearly there. Just need to pull out the putter and tap the ball into the hole
Please create an improvement request for each of your ideas in the "Improvement Requests" category over to the right.
This creates a voting block where other uses can vote up your idea
Twitter: @bradleysauln
@bradley_sauln Thanks for the input!
https://forum.onshape.com/discussion/comment/24322#Comment_24322
