Creating Surfaces from three or more points.
robert_melascaglia
Member Posts: 42 EDU
Greetings all
I have solid geometry and I like to select four points to create another surface area. How does one go about this, thanks.
Robert
Robert
Here's some steps to take. It's a little winded, but there's a concept that needs to be had.
Below I have 4 random points in space:
From here I create 2 vectors (bridge curves) defined from 3 points:
One thing to note about creating curves with points, direction ain't possible:
Let's move on, there's an answer at the end. Create a plane from 2 vectors using sweep:
Remember a sweep with 2 linear curves produces a plane that I can sketch on.
I create a sketch and another vector in the sketch:
Now I have direction defined in a sketch:
I can drag the direction around in the sketch giving me the control I want:
This is a long winded answer to your question and I'm trying to illustrate a concept used in surfacing. Sometimes you have to build a surface to build another surface. It's like chess and requires thinking 1 or 2 moves ahead. Worry about direction and your constructs based on direction vs. worrying about position. Position's easy.
Don't try and build a surface from points vs. try and build the constructs that are going to control and build your surface.
Don't freak out, when I'm designing, it take minutes to build my surface constructs. I blast through it.
It's a 2 step process: build the surfaces to build a surface.
On a side note, couldn't you use a three point plane instead of the swept surface? I understand this was for illustration purposes, but I'm wondering if there is a specific reason I'm not aware of.
There's so many ways to describe a plane, any will do. A plane is just a point & vector. If you want to control the "x" direction, then it's 2 vectors. With sweep the "x" direction is defined by picking sweep & path, the curve you pick 1st is typically defining the "x" direction and you need to figure out how they're doing it. In my case, I don't care which way horizontal & vertical are oriented as I'm not aligning to 'x' in any down stream operations. Sketch direction in this example isn't important.
There was a time when the thought was the world should be thought of as points & vectors. Then someone thought up a boundary representation.
Solid modeling and those 3 planes has simplified things so much, we've forgotten about position & direction. It's old school, it's cool.
To me surfacing is easier than solids and the controls you get allows you to build anything.
I have a lot of SW files inside OS and none of the datums came over through the translations: IGES, STEP or Parasolids. I have the geometry and no datums. I've lost the design intent. Where's the project skeleton? I'm only getting half the puzzle pieces from SW and those who use planes & axis. Had they used curves, edges & surfaces. Guess what pops up in a translation? I get everything if you use surfaces.
I use analytic surfaces in my OS designs and when they go back to SW, everything is there. The data returning to SW is better than the data I received from SW.
