Can I reference Mass Properties in an Expression?
adrian_vlzkzadrian_vlzkz Member Posts: 258 PRO
Could find anything on the help, basically trying to see if I can use "system" values when writing an Expresion for a Variable. (Mass, Volume, Density...)
CAD Engineering Manager
    I don't think so but this would be and handy
    @adrian_velazquez
    It would be pretty easy to make a "measure volume" custom feature which sets a variable to the volume of a selected part.  Density (and hence, mass) are trickier because FeatureScript does not have access to the material assignment of a part.  What is the overall goal here?
    The goal is to Drive a shape (a couple of dimensions) based on a specified weight.
    @adrian_velazquez
    Maybe I misunderstood.  Do you just want to set a variable to "3 m^3" or "10 kg", or do you want to set a variable to the measured volume/mass/density of an existing part?
    I want to set a Variable to 1kg then have my dimensions driven by an expression that uses the Volume. Density would be needed in my expression to know my target Volume
    This should be possible using an "any" variable
    billy2billy2 Member, OS Professional, Mentor, Developers, User Group Leader Posts: 2,014 PRO
    edited February 2019
    Can you pass the context to a variable's function?
    function() { return evVolume(context, {"entities" : qEverything(EntityType.BODY)}); }
    Hoping this will return the volume of all parts at the position it's in the tree.
    ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,175
    No, we deliberately block usage of context in expressions (because it can lead to some really unintuitive results -- what if the user does an opSomething call in a parameter?) but a custom feature can easily do thiis.
    shouldNotBePostingshouldNotBePosting Member Posts: 10 PRO
    Honestly, referring to featurescript from the variable function may not be necessary, I still had to lookup evVolume. If you're at the need level, just write a featurescript, I can do it in 3 lines of code and have greater functionality with featurescript vs. a 1 line function call.
    I'm going to write a featurescript to set these variables. This is all that needs to be done. Adrian's request is still valid. Why aren't these already being set? The benefit with a feature script is that you can ask which parts to include in a volume calculation which is useful. The globals that you set in a partstudio will have to be "all".
    @shouldNotBePosting
    Not sure if I understand your question, but mass properties can be expensive to compute -- we should not be doing it without the user asking.
    Sorry, I've got too many computers and too many accounts.
    @ilya_baran thanks, I think I have this under control. I'm going to have a featurescript write the volume to a variable using a featurescript.
