Navigating between linked documents/objects
Doug_Jones
Member Posts: 28 ✭✭✭
In our structure, we have documents with assembly models/drawings, along with standard internal components that are linked from separate documents. For the light (non-technical viewers), we want to establish instructions for navigating from the top document objects (assembly model, BOM, or drawing) to the linked component documents (models/drawings). The most intuitive way to do this in my opinion would be to set up links in the BOM. But not sure if this is doable. Anyone have a system or approach for this, that does not include reverting to doing searches?
1
https://appstore.onshape.com/apps/Data Management/IL7KBBHCXND3CH46RW7HUVIFVDJ2O6UM2L3EOUI=/description
