"Update Linked Document"
don_williams909
Member Posts: 138 PRO
Although somewhat of a misnomer, this feature in the assembly tree is kind of a pain in the neck. For starters - we're not updating the document, but the part "to" the already updated document.
Can't we have a simple button to push on the menu bar that will update the parts automatically, without having to select them all individually?
Honestly, the parts should automatically update, since changing a part is actually making a "new" part, and the only thing updating is the part due to being forced to make a "Version" of a document.
There Must be an easier way than all this version stuff, and then all the work we're forced to do, left in its wake...
I hope that made some sense...
My workflow is to start with everything in a document and as assemblies mature, I move'm out into their own documents.
Keeping everything in a document isn't the right workflow either. Moving things around seems to be working. I've moved assemblies back into a document to avoid the update/version paradigm.
Moving docs around will cause you to lose versions, but it's not a concern of mine.
Docs referencing other docs invokes update/versioning and I also like this.
