View Cube Zoom?
owen_sparks
Member, Developers Posts: 2,660 PRO
Hi folks.
I'm wondering if I'm alone in finding the behavior of clicking on the view cube annoying? I like the rotation but feel that it shouldn't automatically zoom to fit. I'd like to be able to turn that off in a preference or at least hold a modifier key to inhibit it.
Cheers, Owen S.
1
I have had the same thought. Then thinking more; how would it know where you want to focus? Since you move the cursor to cube, the software does not have the center of rotation 'automagically' like when rotating with mouse. It would be more frustrating to have it rotate with part not located on what I want (although mind-reading could be handy)
So using the present keyboard shortcuts is a good way to go for me. Normal (N key) does close to what you are asking. It rotates and centers on selected face AND does not change zoom factor. I love that - all without moving the cursor away from the area. Along with N, I am using window zoom (W) more, esp. on large jobs when the mouse wheel takes too many spins to get zoomed. Then the arrow keys are nice to make 45 degree snap rotations, keeping whatever odd angle the part is at.
I suppose the view keyboard shortcuts (shift 1 - 7) could function without changing zoom and center on the cursor. I would vote on that if you want to do an IR. Like @brucebartlett said it seems the cube is fine for overview stuff. When I am working close in, moving the cursor all the way to the cube is just too far.
I expect when the OS folks implement custom shortcuts our dreams will be wildly exceeded...
I suppose center would then be center of viewport?
It would really be handy for checking alignments, overlaps, gaps, clearances at a zoomed in level.
I use it constantly. In Onshape, having to zoom in again every time is annoying.
If you want to zoom out when you're "lost in the maze", you can simply press F to zoom to Full view.
One drawback of switching to a 'true' view without zooming out, is that you can suddenly have your view blocked by some other object that is in the way of what you really wanted to look at. But my experience with other tools (mainly Blender) is that this is a more than acceptable trade-off.
