Need Help
adam_peasley
Member Posts: 4 ✭
in General
Hi,
I was wondering if anyone can help me with this, is there anyway I can import these files to onshape?:
(https://www.chaoscorps.org/bombshell-full-cad-release/ and https://www.solidworks.com/sw/commun...nfirmation.htm), I've been having a hard time trying to get these files onto onshape, if it is even possible.
I poked around a little in the zip file, and found an assembly named BombshellFullBot.
I renamed the zip file BombshellFullBot.zip, and imported it to Onshape. Here's the result.
There's another folder inside it with the "V1" files.
You may need to mess around with the names of the zip folders etc (see Onshape help for importing assemblies here) to be able to import the V1 Assembly.
Here's a link to the document: https://cad.onshape.com/documents/8c253992b06be30dfaa51416/w/a0ce6e9b223054fe82d0e783/e/0f6809f22c1705954fecebc8
You can make a copy and have fun with the file!
