sweep tool - using a partial path
IsoTherm
Member Posts: 66 PRO
Greetings,
I have a path, defined by a 3d spline, and a profile on a sketch at the start end of the path. The profile is two concentric circles. I want to sweep two times; the first time I want to extrude (add) for only a short section of the path, the second time I want to cut out the center hole for the entire length of the path. Is there a way to do this using the same 3d Spline?
Thanks
Isotherm
Thanks
Isotherm
Onshape, Inc.
So here's a partial of a curve:
Using the wrong starting circle:
Using a proper starting circle:
So possibly the correct answer to your question is both yes & no.
Using the same curve twice won't work because sweep uses the entire path, not a partial of the part where the profile exists.
Just create a normal plane along your path and that'll work.
https://cad.onshape.com/documents/7d1bc5d056ac715a7190c886/w/66663949e9516193efa40c84/e/adc1d1b4518ac63dea3b56ea
