Ability to Modify a part from its derived representation.
Smilesonica
Member Posts: 27 PRO
Imagine a situation where you have two sub-assemblies built in two part studios. These two subs must interface to one another. So to design the interface on part studio B, I start be bringing a derived part from part studio A into B. While designing the interface in B, I decide I want to modify the part from studio A based on the geometry from studio B. I want the ability to modify a part by modifying it's derived representation.
On a part studio Im working on, I started with a derived part. When working in the part studio there was a feature that I wanted to add to the derived part. Happily it seems that OnShape does let me add features to a derived part and merge them correctly to the derived part. The new features merged correctly, there weren't new parts floating in space or anything. However, when I went back to the derived part's originating part studio, the features didn't transfer back to the root part studio. This would be extremely useful!
I think at the moment the only way then is to derive parts in both directions, derive A to B and also derive B to A, but then I would be constantly going back and forth between part studios. As I said, it seems that OnShape, intentionally or not, already allows a derived part to be modified. This improvement would give the designer the option to have these changes propagate back to the originating part in its home part studio.
Thanks for looking at this!
So the first part of this problem is a problem that exists in OS already. I was actually just reading another thread you posted in about being able to bring multiple imports into the same part studio. Both parts are imports from SW. So Im stuck with them being in seperate part studios. Edit-in-context would work, yep, but I hadn't built an assembly yet. I used derived from part A to make a change to part B. Then, as an experiment, I decided to try editing the derived part. To my delight, I was and am able to modify the derived part. Why not just let me make those changes stick to the original part? Why does OS care if I want to edit in a part studio or an assembly? Apparently, it's possible in both cases, just in the derived, the changes are blocked from going back to its original tab for some reason. Why let me modify the derived at all if I can't make the changes stick.
@lougallo
what are your thoughts on this?
Thanks for your thoughts all.
