Moment of inertia reference point
michele_portioli861michele_portioli861 Member Posts: 4 PRO
I can't really find anywhere what the reference point is for the calculated moment of inertia in OnShape. I'd expect it to be either the origin or the c.o.g. of the assembly.
  • john_mcclaryjohn_mcclary Member, Developers Posts: 3,890 PRO
    I'm not sure where the default position is.
    But you can set a reference point with a mate connector.
    @john_mcclary
    I've looked into it and without a specific reference frame, the moments of inertia are calculated about the center of gravity of the selected instance(s).
  • michele_portioli861michele_portioli861 Member Posts: 4 PRO
    Thanks for your answers!
