Extrude Remove does not operate as expected
dana_kelley262
Member Posts: 31 ✭
I detailed this in Community Support so I'll pass the link to that discussion. It really does look like some sort of bug.
https://forum.onshape.com/discussion/11872/extrude-remove-does-not-do-as-expected#latest
Things to consider... it worked fine until I reordered the feature list to be more readable being careful to put things in the right order of dependency. All but the last Extrude worked properly. The above link has the details. The work around is also mentioned in the discussion.
