Override mass properties for imported IGES file?
rob_rowland
Member Posts: 19 ✭✭
in General
I need to calculate exact mass, center of gravity, and moments of inertia for a large assembly. To do that, I need to ensure that mass properties have been accurately applied to all of the contained components.
Many of the assembly components are CAD models given to me by my suppliers in IGES format. IGES format imports into Onshape as hundreds of little surfaces. I have included a section view screenshot so you know what I mean.
My suppliers have already given me a mass and COG position for each component. How can I override the mass properties of this imported geometry in Onshape (including the surfaces), to have the provided mass and COG? I cannot accurately calculate assembly mass if the included components do not have an assigned mass.
This is a critical feature that every single other 3D CAD tool I have used can intuitively accomplish (Siemens NX, Catia V5, Solidworks, etc.).
I had thought of doing exactly that, so thanks for the confirmation of it as a workaround. Very tedious to do this for all my imports, but I guess that's the only option.
@NeilCooke
Sad to hear that it can't do this but I understand. If there is in an improvement request already in the pipeline, please please make this a priority. It's such a critical feature for integrators and OEMs (like us) that import a lot of packaging CAD. Having this feature will save my team huge amounts of time.
Tried to hunt down the specific FS mentioned but not finding. If someone knows the name of the FS it would be appreciated.
Lots of files sent from vendors import as nothing but surfaces with no mass but CofG location given in drawing.
Request has been put in for CoG symbol in drawings. Please vote up.
https://forum.onshape.com/discussion/comment/23650#Comment_23650
Here is my FS to set material + weight:
https://cad.onshape.com/documents/3ca261a95938af152088fca8
