jumping from wrong side of line
AnotherOnshapeUser
Member Posts: 28 PRO
in General
Problem happens all the time:
1. Draw a line from the side of line A to the right
2. Specify length
3. line A jumps over to the left !!
how do you stop this? I would think that if I draw a line starting at point X, and stop it somewhere, and enter a length, it would be SO logical to continue the line or shorten it to that exact length. I do not want to have to add constraints or a 'fix' to the existing line, I just want Onshape always to add length in the direction I was already going.
This also happens when you are doing an offset: 1. draw an image. 2. Select it and request 'offset' and change the offset distance 3. POOF ! The image jumps over to the side.
Why not just assume that wherever I started was where I WANTED to start?
2. Specify length
Instead of click, draw, insert length, click, draw, insert length, which is quite intuitive, one must constrain, click, draw, insert length, constrain, click, draw, insert length, and then remember all those constraints later on when you want to change something. This is so obviously and so easily a fix it should be done. It does not require artificial intelligence, just tell the program to remember where you started drawing the line and measure from there it should be a no-brainer.
Example
thanks for the detail. Tell me! Does it ALWAYS move to the right?
thx
The big problem with this is that a drafter can work for an hour on a sketch, and then add a line and not notice that the starting point jumped and changed the sketch, and then incorporate errors into the job. Have to watch it like a hawk!
I've had a lot of trouble with constraints. Often I think I've got a sketch tied down and then Pow it jumps all over the place. Do I really have to constrain every end of every line? How can I do it easily?
This may help: https://learn.onshape.com/courses/fundamentals-sketching
Please take your time @AnotherOnshapeUser and master 2D sketches and constraints. They are the foundation of your entire model.
One blue line can set you back hours of chasing your tail trying to fix a very simple problem down the road.
Whether or not you must constrain the line at the beginning of your work flow, or at the end, makes no difference. Before you close a sketch you should ensure all points and lines are Black anyway.
Constraining early will also make your life easier in many ways, for example: any time you construct geometry with circles and tangents. They will turn your sketch inside-out with even the slightest over-drag of the mouse. Sometimes the only recovery is to delete the circle/arc and re-sketch it. That's just how it works. How can the software truly know what direction you intend a line to extend? Should it record every mouse click and pixel location you mouse was like a movie, so when you come back to it a week from now it will know you intend to extend left instead of right? Sounds far fetched when you think of it that way right? But how else could it work? will it need to remember the creation time of each entity so the earlier entities drawn are "less movable" when adding dimensions to new lines?
There is a old saying that I haven't seen proven wrong yet in computing: Garbage in - Garbage out;
Computers are dumb, WE are what make them do the amazing things.
An entry level designer needs to understand this and it's not easy. More time needs to be spent here on the basic sketch concepts. It's not easy for new users. You can't short cut this conversation without having further problems later on.
In a sketch, black is good and blue is .......? Depends if you know what you're doing.
Turn constraints on and try to understand how the constraints work. Onshape has a lot of automatic stuff like picking up horizontal & vertical to origin. Some times I think it's too sticky.
It's not drafting, there's a lot more to it. Design intent, what should the sketch do?
D-cubed is nothing more than a linkage solver. Draw a four bar linkage and spin the driving link. It works perfectly the way it should.
Been using parametric CAD for over 10 years, still something new to learn even on the basic sketching tools.
