Interaction with manufacturers
Konstantin_Sh
Member Posts: 26 ✭✭
We have multiple projects which are meant to be deployed at multiple manufacturers - usually a few manufacturers per each project. And we have two ways of dealing with them: in the old style - sharing manually a pack of documentation collected for each of them, that requares searching for each part and each drawing and exporting it in the correct configuration and appropriate format and manually attaching info of a quantity requared. But this piece of functionality within OS turned to be pretty weak - no group export, no way to switch from part to drawing, no search-based actions at all. And because of this the workflow we where trying is to create one document for each project shared for each manufacturer, which contains part models added to the assembly tab and part drawings added in pdf format. But still a lot of manual actions requared, we can't link drawings in native OS format between projects and can't find if the part has a drawing at all. The functionality which would solve almost all needs in this area is:
- multi-property search objects within the document or external which collects references to the parts, drawings and pieces of BOM's ( with respect to the search conditions applied) and provides exclusive accsess to it's elements (not document-wise) with respect to this search object share permissions.
Also I'm curious what workfwlows for manufacturer interaction are used by other users and if there are some reccomended ones by Oshape?
What if there was a "linked tab" option for documents? I envision creating an empty document, then creating read-only links to existing tabs from any other existing document. This way, I can link-to and any specific entity. If I want to share one specific part out of a multi-part Part Studio, I can still pull that part into a new assembly easily enough.
I know for certain Onshape is looking at providing solutions that either encompass, or override the need, for both items 1. and 2. you have listed there. As always, it's tough to provide any kind of timeline as to when we'll see these new features though. Have you reached out to be added to the associated Improvement Requests? We prioritize based on the number of customer hits - the more hits, the sooner we should see this functionality.
Thanks again for your feedback!
